What happens if a 2001 Civic has had the CAT removed?
Old Jul 13, 2012
AndreaMullen's Avatar
AndreaMullen is an unknown quantity at this point
I have a 2001 Honda Civic EX, 5 speed manual transmission. I was having some issues with it. I would be driving, and everything would be fine. The clutch felt wonderful, it shifts smooth, and drives like a dream. However, it will randomly just stop accelerating for no reason. Ill pull over, shut the car off, then a few minutes later, it will be fine. When the issue comes up, I can still shift, still rev the engine, and and still drive...just not over 25 mph. The RPMs are fine. I had the clutch looked at, the throttle cable redone, the radiator hose is being replaced, and the oil was just changed. I had a mechanic look at the car, and the CAT is missing, and the O2 senser is not working. Would that cause the problem Im having with the car?
Old Jul 13, 2012
Re: What happens if a 2001 Civic has had the CAT removed?
get a cat. not the ones that meow.
Old Jul 13, 2012
If the original cat broke the element apart, it could have left pieces in the rest of the mufflers or pipes, bouncing around and randomly blocking exhaust flow.
The rest of the exhaust needs the loose debris cleaned out, if this is what really happened.
Misfire or severely rich running is what normally causes physical damage to a cat.
The cat element breaking apart can cause physical damage to the sensing tip of the rear O2 sensor too.
HTH
Old Jul 14, 2012
Derky89's Avatar
Derky89 is an unknown quantity at this point
The cat does nothing but make ur emissions good for cali. I got headers and no cat. It just boosts ur horse power slightly. Better air flow
Old Jul 14, 2012
anibis's Avatar
anibis will become famous soon enoughanibis will become famous soon enough
It also makes the car legal in the U.S.
Old Jul 14, 2012
04 Honda Civic's Avatar
Doubtful.
Old Jul 15, 2012
i would only recommend removing cat only when owner do know what they are doing.
Old Jul 21, 2012
scooty's Avatar
scooty is on a distinguished road
The mice come out to play...
Old Jul 22, 2012
MindBomber's Avatar
Live for the Twisties
Maybe by 1hp at the expense of quite a fuel economy loss.
mattdoc
Mar 14, 2017 12:10 PM
CapYoda
Nov 11, 2001 05:17 PM
Lightman
Nov 10, 2001 06:44 PM
liljoe
Nov 4, 2001 01:27 PM
HitlistCivic01
Oct 27, 2001 07:47 PM
