Transmission help
Old Jun 20, 2012
thhande's Avatar
thhande is an unknown quantity at this point
Transmission help
Ok, this is a long story but I'll cut to the chase. Car is my wife's 02 Civic HX 1.7 VTEC 5SP with 64 K miles on it. Incidentally, this is the ninth Honda I have owned over the last 36 years or so, so I have lots of good experience with them in general, but I'm certainly not a mechanic.
4 K miles ago (at 60 K miles on the clock), it started popping out of 5th gear so I took it to the dealership (which shall remain un-named for the moment). Their solution was to "replace syncro set," $1,600.00. It took them two tries as they "broke a part" on the first attempt and had to reorder. After the repair, 5th was fine but I noticed that 3rd was demonstrating the same symptoms, forcing the shifter back (toward popping out) on acceleration. However, it never actually popped out so I let it go. 4 K miles later, last weekend, I started getting a pronounced whine from the transmission on acceleration in all gears, particularly first through 3rd. Back to the dealership. Diagnosis is "bad input bearing, could not be related to earlier repair (hence it is my problem), bearing is an integral part of the transmission and cannot be replaced." Recommendation: "replace whole transmission with used unit, $2,695.00."
I'm suspicious, let's just leave it at that. Things don't seem to add up.
Questions: What's this "input bearing" and is it really not replaceable? Is it reasonable to assert that the bearing failure "could not" be related to the repair done only 4 K miles ago? Am I justified in suspecting that they well might be trying to avoid paying for an expensive repair on a botched job now (and possibly more in the future) by asserting that it's my problem, and solving the potential future problem by saying the whole transmission needs replacement? Obviously, I can't "prove" that theory. What's my next move? Thanks so much to anyone who can help.
Tom.
Old Jun 20, 2012
thhande's Avatar
Re: Transmission help
Afterthought: Or am I just being paranoid?
Whitexj
Sep 30, 2015 02:04 AM
jackoncruzpr
Sep 29, 2015 07:59 PM
C-Hamm
Sep 28, 2015 10:31 PM
Elciteeve
Sep 28, 2015 12:40 PM
jerry38
Sep 20, 2015 08:38 AM
