Abs light & p0740
Old Jun 13, 2012
taz13's Avatar
taz13 is an unknown quantity at this point
Abs light & p0740
Hello everyone
I just purchased my first car 2001 civic dx but like any first car its got its issues. I ran a scan and got a p0740 code but my transmission shifts and operates perfectly fine, so what could cause this code to come?
Second the car gets a ABS light on the dash when going on high speeds (100-125 kph) and stays on UNTIL I turn it off the engine. once I turn it back on it doesn't come back until I hit same again speeds. I ran the scan while the light was on but got no code, anyone know what could be causing this?
Thank you and sorry if this was covered in another post, i couldnt find it
Old Jun 14, 2012
fsckewe's Avatar
fsckewe is an unknown quantity at this point
Re: Abs light & p0740
No clue about the p0740 code.
Most OBD 2 scanners can't read ABS codes. Although there is a manual way to read the ABS codes with a jumper. Search for it.
Here you go:
https://www.civicforums.com/forums/3...ml#post4467241
Old Jun 14, 2012
P0740 TCC slip detected
A bulletin here just for 01's:
http://ww2.justanswer.com/uploads/th...tc_740_tsb.pdf
and a thread about it:
https://www.civicforums.com/forums/3...er-issues.html
HTH
conspiracy90
Jun 7, 2023 01:01 PM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
Blazz
May 25, 2015 10:56 PM
werdnahall
May 17, 2015 11:37 AM
davidarenberg
May 16, 2015 08:45 AM
