car pulls to the left
I just put on a set of gold line springs. The car looks great but Im having a problem with it pulling to the left. I took the car to merchants and they did a 4 wheel alinement and charged me $50. After having this done if i take a right turn the car drives great. If I take a left turn the car pulls to the left. I have no Idea what could cause this and since the car is lowerd im not sure if they will even want to mess with it again. When they alined it they made sure to put on the bill that it was lowerd and that they alined it to factor sandards.
when u installed your springs do u put them in all the same why like as in it says goldline on only one side of the spring and that part faces outwards on each corner. sometimes the springs can mess up if it isnt. or maybe you just wiegh like 500 lbs. but i doubt that.
They didn't do an alignment and if they did it was not properly done. Make them do it again and give you a print out. Before you do that call a Honda dealership and speak to the service department and ask them what the specs for the suspension should be. That way you know if they are lying to you. If they tell you something wrong tell them well no it is supose to be ......
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
tylerginevan
Apr 27, 2015 12:29 PM
dragonsblood
Apr 27, 2015 12:28 PM
GH04si
Apr 15, 2015 08:13 PM
