o2 sensor, need second opinnion [vid included]
Old May 8, 2012
Mr Belvedere's Avatar
Mr Belvedere is an unknown quantity at this point
hi guys, new here, have yet to post on/in the new member section, but im a long time lurker..
I dont want to get too much into the issues, because i will make a proper thread tmrw. i just wanted a quick second opinion on the condition of the O2 sensor in the video and what could of caused it.
background info:
recently bought my 2001 Black civic lx
CEL came on shortly (obviously -___- )
trip to pep boys tells me cylinder 2 and 3 misfire and catalyst inefficiency (3 codes total, the guy read em to me, didnt give me the exact numbers)
my assumptions
/knowledge of issue
ok so what ive found out is that if my o2 sensors are not working, then it could be causing bad fuel mixtures and causing misfire... eventually leading to my catalyst getting destroyed. evidence of this would be black carbon depositing on the sensor.
or
cracked cylinder or something similarly worse is allowing antifreeze to leak, get burned, and ALSO kill my cat and o2 sensor. in this situation WHITE residue on the sensor from combusted antifreeze. god i hope not.
or
im missing something obvious
where i need help:
i need someone experienced to look at this sensor and tell me what the wear on it suggests. that would be a step towards solving my cylinder mystery. once again i just got this car and im going to be so mad if the engine is shot.
But wait theres more to come...
when i have time tmrw i will sit down and write a thread with all the symptoms and what led me to get these engine codes checked to begin with...(hint: i initially suspected tranny is hurt, guess not)
LAST BUT NOT LEAST: THE VIDEO
http://www.youtube.com/watch?v=jVak-0uu6oA
Old May 8, 2012
Re: o2 sensor, need second opinnion [vid included]
Video is irrelevant. You cannot evaluate an O2 sensor that way.
Half or more of your assumptions should not be used.
The theory may be right, but they do not apply to this situation yet.
First and foremost:
Figure out and fix the misfire problem.
This needs taken care of first.
Plain and simple, even if the fix is not simple.
Then worry about fixing (replacing) the cat.
Old May 9, 2012
04 Honda Civic's Avatar
By the looks of it your probably burning coolant.
Test for combustion gas in your coolant and then go from there.
At the very least its probably going to be a headgasket.
Car overheat? Coolant coming out of overflow tank?
Old May 9, 2012
WalkerTech's Avatar
WalkerTech is an unknown quantity at this point
Mr. Belvedere, I am a product specialist with Walker Products, a manufacturer and worldwide distributor of oxygen sensors. Please follow the link below to see pictures of common failed O2 sensor conditions. To me, the one in the video looks to show characteristics of antifreeze contamination, just as the gentlemen below said. http://www.walkerproducts.com/wp-con...html#/8/zoomed
Old May 9, 2012
scooty's Avatar
scooty is on a distinguished road
Head gasket time!
But first, pull the radiator cap (cold engine!), start it up and look for air bubbles in the antifreeze.
Then buy the test kit that checks for combustion gasses in the antifreeze.
Pull all 4 plugs take a pic and post on here. After the plugs are pulled, look down each tube and look for oil that could have got past the valve cover gasket and onto the plugs causing misfires. Inspect each coil pack carefully and look for hairline cracks.
BootyDo
Jun 21, 2016 03:45 PM
mistermenphis22
Jul 13, 2015 04:43 PM
Jul 12, 2015 11:54 AM
juror
May 26, 2015 06:35 PM
wh3nw0rdsesc4pe
Mar 23, 2003 09:57 AM
