Idle Problem
Old Apr 23, 2012
v2famous's Avatar
v2famous is an unknown quantity at this point
Idle Problem
When I have my ac on
I press the pedal and the pedal doesn't stick but it revs goes down then revs and goes down (without my foot on the pedal)
It's only when I have the ac on
Old Apr 23, 2012
Re: Idle Problem
Ummmm.....I'll stab at it
Maybe...
Idle relearn
Stuck IAC
Clogged IAC (if it is the type with a screen in it)
May be normal, too. The AC makes a significant load on the engine. It is noticeable as it cycles on and off. The engine RPMs should stay relatively steady as the AC cycles on and off though.
Is the check engine light on? What codes?
HTH
Old Apr 23, 2012
v2famous's Avatar
Re: Idle Problem
Maybe...
Idle relearn
Stuck IAC
HTH
No check engine light
The ac doesnt get cold and there is Frion in it (I don't know if thats the problem)
Old Apr 23, 2012
Re: Idle Problem
Can't answer that without knowing exactly what the compressor is doing, and what the engine is doing. And maybe what the AC system pressures are when this acts up (only if the AC engages at all).
A system that is seriously overcharged may not cool, and could make the engine bog way down when the comp kicks on. Still, I can't tell what is going on from here.
If the AC doesn't work, then leave it turned off. Or get it fixed.
HTH
TXcivic2001ex
Air Conditioning
23
Jul 20, 2020 07:27 AM
crowtoo
May 11, 2015 06:50 PM
jakeconnor
May 5, 2015 07:30 AM
vtechcivic
Apr 21, 2015 06:58 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
