Egr
Old Mar 12, 2012
LaurentYe's Avatar
LaurentYe is an unknown quantity at this point
Egr
I have a reoccurring P0401 EGR error for my 2005 Honda LX (D17A1) and it is time for emissions test. I tried to a new EGR valve and it didn't fix it.
I want to take off the manifold and scrub the ports on the intake side. Is there a way to loosen just the manifold and scrub or do I need to take the TB off and then the manifold just to reach the ports.
Also, other than the DIY guide below:
https://www.civicforums.com/forums/1...fold-swap.html
Is there another DIY guide for removing the intake? When I put the intake back on, should I buy a new basket?
Thanks for your help!
Old Mar 13, 2012
fsckewe's Avatar
fsckewe is an unknown quantity at this point
Re: Egr
Why did you replace the EGR valve first? Did you test it? Seems like a waste of money. That $125 could have been better spent on a manual (~$60) and a steak dinner.
Yes you need to take the intake manifold off to access the EGR passages. If you don't have a manual find a good online source for diagrams.... I like hondapartscheap.com.
Check out this post:
https://www.civicforums.com/forums/3...-passages.html
Edit:
And yes, I would install new gaskets. #1, #8 and #10 in that image. And some suggest injector o-rings(#20 and #21) if you remove the fuel rail. Oh and put some motor oil on the o-rings when you reinsert the injectors. Makes life easy.
Galbir
Aug 31, 2015 07:05 PM
GritzNGravy
Aug 19, 2015 03:03 AM
2005seTO
Aug 18, 2015 12:45 PM
General 7th Gen
Jul 9, 2015 10:17 PM
92hatchbackcx
Jul 7, 2015 08:23 AM
