engine help
Old Mar 10, 2012
atxman's Avatar
atxman is an unknown quantity at this point
engine help
i've got an 01 ex with 230,000 miles on it. recently started knocking. wondering if that means i should just go towards a full swap or stick to my low budget and try to make small fixes here and there.
Old Mar 10, 2012
lazlong's Avatar
Re: engine help
Are you sure it's not the valves tapping? When was the last time the valves were adjusted?
Have it professionally diagnosed to determine what's wrong. If it's the bottom end just get a new engine (usually $500-1000 for the engine and $1000-2000 for labor). If it's the top end the valves need to be inspected to determine if you need new valves or a complete head. And replacing that depends on the cost of a new head or valve replacement. New heads can be had pretty cheap on eBay, craigslist, or here: http://www.car-part.com/
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
bluecoupe
Jan 23, 2002 05:50 PM
MyOtherRideIsBritney
Jan 20, 2002 03:16 PM
Cross
Jan 6, 2002 01:31 AM
supercivic01
South
Nov 30, 2001 11:27 AM
