Walbro Install help
Old Feb 29, 2012
army12bc's Avatar
army12bc will become famous soon enough
Exclamation Walbro Install help
Ok so i am doing a walbro fuel pump install and a return line conversion. when i put the pump in i get no fuel. got power as i am running it from a battery charger for now just to get it going. when i put the pump on with just the pump itself and power i get fuel out. then when i blow air through the cap of the pump housing it does not come out unless i block the outlet to the old intank regulator. when i put the blocking hose on said regulator outlet and install i still get no fuel. i'm thinking the block hose isn't air tight. could that be the problem? i called dezod and they said to run the pump to a barb fitting cut into the top of the pump housing and run a braided line all the way up. unfortunately i'm so trying not to spend more money on this build as i still need coolant hoses to covert to the electric water pump and still have alot of work to do. it has been one thing after another with this build from a belt not fitting to sensors just snapping off for no reason blah blah.. HELP!!!!!!!!!!!!
Old Mar 1, 2012
army12bc's Avatar
Re: Walbro Install help
went to innovative motorsports today and they told me same thing as dezod. so i did the line straight from the pump out and used the stock as return. still no fuel.!!!
Old Mar 1, 2012
army12bc's Avatar
Does any of the abs wiring affect the fuel pump. I'm tracing the diagrams and PGM FI 2 seems to go to an Inertia switch and then to the SRS and IGN via No. 17 (15A) blk/ylw?
I took out most of the abs system wiring and i have it all cut out of my dash harness!
ANYONE THERE?
Old Mar 15, 2012
army12bc's Avatar
bump
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
mrwhos
Aug 11, 2015 02:03 AM
17
Jul 23, 2015 11:48 PM
EM_WON
Jul 22, 2015 06:49 PM
