2003ex timing belt question
Old Feb 15, 2012
2oo3EX's Avatar
2oo3EX is an unknown quantity at this point
I have a 2003 ex that I got with 210k kms and I was wondering if there are any telltale signs that it's has been replaced or not and if it does need a new one is it easy to do?
Old Feb 15, 2012
SuperMan2012's Avatar
SuperMan2012 should not be trustedSuperMan2012 should not be trusted
Re: 2003ex timing belt question
How many miles is 210K kms?
Old Feb 15, 2012
2oo3EX's Avatar
Sorry 130k miles
Old Feb 15, 2012
Sorry 130k miles
It's hard to tell if it has been replaced or not.
It's not easy to do, as it takes hours to do by a mechanic. If it hasn't changed yet, you need to do it as soon as possible, and also change the water pump at the sametime.
Old Feb 15, 2012
it's not necessarily hard to do, per se, just really time consuming, and you gotta be meticulous with lining up the timing marks.. You also need a crank pulley tool, which you can usually rent. I figured I'd be using it a bunch, so I bought it for $50.
You also gotta be really, REALLY careful with the crank position sensor. You kinda have to remove it to get the belt off. Mess that thing up, and your car will be running rough with the CEL on.
First time I did it, it took me 6+ hours to do. Now, I can start the job and have the car fired up in about 3.5-4 hours.
We have a good DIY guide for it on the forums.
Old May 27, 2012
palsana's Avatar
palsana is an unknown quantity at this point
I have had this problem ever since i had 130k mi on my 2003 Honda Civic EX sedan Car. My CEL is always on, the timing belt was changed right around 95k mi and i think i did not do it myself, but i surely must have messed that thing up? how do i ever will know that is the problem?
Old May 27, 2012
MindBomber's Avatar
Live for the Twisties
If only you knew xRiceboyx's history with his CP sensor, Palsana.
Old May 27, 2012
Lol, I had issues with the CP sensor, but it was the TDC sensor is what you're really alluding to, Austin. That's the one that decided it wanted timing belt for breakfast one day
as for the issue at hand, it wouldn't hurt to double check the alignment of your timing. Just take off the upper timing cover and rotate the crank pulley, see if the TDC marks line up.. Check it a few times for redundancy sake. If not, you got a few hours of work ahead of your.
mattdoc
Mar 14, 2017 12:10 PM
dosmastr
May 5, 2015 12:19 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
bsmiley
Apr 27, 2015 01:27 PM
dano2005
Apr 14, 2015 01:58 AM
