04 civic 404/420 codes
Re: 04 civic 404/420 codes
How about posting the entire code next time.
P0404 is EGR valve insufficient lift, the PCM didn't see the desired change in sensor voltage when it commanded the EGR valve to open.
P0420 is cat inefficiency.
Not necessarily.
The EGR needs diagnosed first.
Then fixed for whatever caused it.
Clear codes.
See if the cat code comes back, before condemning it. Then figure that one out (not always a bad cat, but usually is).
Clear codes.
rcolosi
Apr 29, 2015 07:48 PM
tylerginevan
Apr 27, 2015 12:29 PM
dooner24
Apr 14, 2015 07:51 PM
