Window Barely Goes Up especially when wet? 2003
Old Feb 4, 2012
chiphum's Avatar
chiphum is an unknown quantity at this point
Anybody have front windows that will barely go up? We have to raise the window half way then 1/4 down then repeat. 2 Steps forward one step back! Its like the regulators in these windows just aren't powerful enough. I don't know what a fix would be because it works just not well. Thanks for any help.
Old Feb 4, 2012
Re: Window Barely Goes Up especially when wet? 2003
Make sure the glass hasn't come off track at the front edge and is trying to go between the rubber and the steel track.
It should stay within the rubber seal.
Lower the glass. Clean the glass run channels with hot soapy water. (The grooves where the glass rides up and down).
Get silicone lubricant in a spray can, or graphite. Do NOT use anything with oil, it can ruin the rubber seals and attract dirt and grime.
Lube the glass run channel seals real good, run the glass up and down several times to distribute the lube down the seals inside the door.
Just lubing with silicone spray usually helps a bunch.
Old Feb 5, 2012
Kennykid2002's Avatar
Kenny the Ricer
My driver side window motor in my 03 has been going bad for the past 15 or so months
It comes down fine, but going up, the last 1/3 is a struggle
I have to get my motor replaced, but it works for now, so I haven't dealt with it
Knowing 7th gens, If I fix that, 3 more things will break down
Old Feb 5, 2012
The motor/regulator either works or it doesn't. If the motor was the problem, it would drag all the way up.
Here's some C&P from Honda Service News, Oct 04:
Got a ’01–05 Civic in your shop with one or more
power windows moving a tad on the slow side?
The likely culprit is run channel friction. Power
window motors and regulators rarely cause this
problem; they simply raise and lower the glass
like a jack.
1 remove the two bolts that hold the
glass to the regulator.
2 Check the run channel friction by raising and
lowering the glass by hand.
• If the glass does not raise and lower
smoothly, go to step 3.
• If the glass raises and lowers smoothly,
compare the run channel friction to the run
channel friction in a known-good vehicle. If
the run channel friction is the same, then
look for other possible causes.
3 Use hot, soapy water to clean the run
channels, then retest.
• If the glass now moves smoothly, reinstall
the glass to the regulator.
• If the glass doesn’t move smoothly, go to
step 4.
4. Use silicone or graphite to lubricate the run
channels, then retest. Make sure you don’t use
oil-based lubricants; they attract dirt and
grime.
• If the glass still doesn’t move smoothly, then
replace the run channels, not the motor and
regulator.
Spray silicone in the run channel seal can work wonders. Have you tried it yet?
HTH
Old Feb 5, 2012
Kenny the Ricer
Good information, however....
Any additional weight on the window causes the motor to sputter and die.
Though, it may be a combination of the problems
Like I said, as long as it works, I'd rather not mess with it for now, until it goes completely kaput
Old Feb 5, 2012
chiphum's Avatar
Thanks for all the advise. I'm gonna try to clean and lubricate the run channels like you all said. I'll let you know results.
Old Feb 5, 2012
chiphum's Avatar
Cleaning the channel & adding silicone lubricant seemed to help. Its still slow but will go up w/o having to reverse it. Thanks for the help. Saved me from replacing the motor.
Old Feb 5, 2012
CraigW's Avatar
My 05 drivers window got wierd, I found that the end of the rubber channel insert was popped out of the metal channel... I pushed it back in but it would not stay in long. I ended up tacking it it place with a small dab of goop.
Old Feb 6, 2012
mac25's Avatar
Dr Krieger of Modification
have you guys owned the car since it was made? do you know if the car was ever in an accident?
i bought my car as a salvage, the right window was always slower then the drivers side window. then i was hit by a canadian post truck, when it came back from the shop they straightend it right and now both windows are normal =D.
Old Feb 6, 2012
Kenny the Ricer
Yep, bought mine brand new, it just happens
Old Jan 3, 2018
rockyrock's Avatar
rockyrock is an unknown quantity at this point
My windows are fine when it's warm outside but lately cooler mornings and evenings have made them slow or even stop when in the down position. I will try to clean and lube the channels but as it seems to be a temperature issue I'm not sure that is it.
Any ideas? Thanks.
Old Jan 3, 2018
Colin42's Avatar
Probably just need to be lubed.
Can of spray silicone with a straw, put the windows all the way down and spray the tracks liberally. then run the windows up and down a few times to work everything in.
Could be that the wires are starting to break and there is more resistance in the wires causing the motors to struggle.
Try the silicone first though
SimpleUser
Apr 24, 2021 02:54 AM
dtdoyle
25
Aug 30, 2015 06:57 PM
redcloud
25
Aug 12, 2015 01:23 PM
jedi
Aug 3, 2015 04:26 PM
ballmich
Jul 9, 2015 11:59 AM
