02 DX power issue
Old Dec 2, 2011
DXperplexed's Avatar
DXperplexed is an unknown quantity at this point
02 DX power issue
Battery lite came on, then relay below the glove box started clicking. As it clicks warning
light changes from battery to engine lite. After a minute or two the clicking stops and just
the engine light stays on. The temp gauge also stops working. The car hesitates at top of
each gear. No power can't rev engine at all.
Dealer replaced computer, solved it for two weeks. Then had reoccurrnce of problem.
Checked alternator and battery. Alternator was missing its ten
sioning bolt, and both mounting bolts were loose. So I replaced alternator and tensioning bolt, and locked mounting bolts in place. Checked battery and its good. Still have same thin wrong with car.Any ideas????
Old Dec 3, 2011
04 Honda Civic's Avatar
Re: 02 DX power issue
You load test the battery? Does it stay above 9.6 volts under load? Made sure the alternator is putting out around 14.5 volts when its running?
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
jbradley4809
Apr 7, 2017 04:23 AM
HiImBrandon
Jun 1, 2015 07:34 AM
Supramk3
May 11, 2015 07:55 PM
skywalker
Nov 8, 2001 05:04 PM
