01 LX Front sway bar endlinks?
Old Nov 23, 2011
DerekxxCore's Avatar
DerekxxCore is an unknown quantity at this point
While in the middle of taking my front lca's off to replace the bushings, I ran into an issue with my endlinks. Apparently whoever had the car before me either tried to replace the bushings or the sway bar- I really don't know. All I do know is that they completely stripped the spot where you have to put the allen key to get the endlink off, so when I put the allen in and my wrench over the nut, the whole thing just spins
I'm guessing I have to cut them off, bought two new endlinks from the dealership (the old ones looked pretty haggard anyway, so I felt it was justified) but is there an alternative to cutting them? Has anyone run into this issue?
Thanks guys
-Derek
Old Nov 24, 2011
lazlong's Avatar
Re: 01 LX Front sway bar endlinks?
Hammer in a slightly bigger allen. Chances are it's gonna ruin the allen so, be prepared.
If you do have to cut them be careful to not cut the threads on the swaybar or you'll need a new swaybar too.
Old Nov 25, 2011
Wow thanks for that, honestly wouldn't of thought to be careful of the sway bar threads. Thanks a ton man!
Old Nov 28, 2011
ubnpast's Avatar
ubnpast is on a distinguished road
You could have gotten brand new control arms with both bushings for about $50 ea, if the allen is stripped you can get a cut off tool (harbor freight has really good ones cheap), I used it to cut off my front LCA bolt which was frozen in the busing, 2 minutes and it was off
Old Dec 5, 2011
Update, bought a cutting wheel for my angle grinder for $3 at home depot, little bastrds came right off. New ones in and good to go!
Makeice3498
Jul 2, 2015 11:13 AM
mrohitredd
Jun 9, 2015 06:37 AM
Rogelio Rey
May 24, 2015 08:30 PM
Dorval Andre
May 1, 2015 09:37 AM
bsmiley
Apr 27, 2015 01:27 PM
