Check Engine Light on for the 3rd time
Old Nov 18, 2011
CIVIC CITY's Avatar
CIVIC CITY is an unknown quantity at this point
Exclamation Check Engine Light on for the 3rd time
i have a 2005 honda civic ex, my car started idling and the neddle went up past the boat but didnt reach the red line. i just had a oil change and had the water pumped replace brand new as well as the timing belt. so when i turn on the car it makes a werid sound as makes a werid noise coming from under the hood.it also shakes a lilttle not viloently thank god,only when u turn it on and push the gas pedal.i ve never had that check engine light on and is always on top of my car.what can this be? please type me back.
Old Nov 20, 2011
CIVIC CITY's Avatar
Exclamation Re: Check Engine Light on for the 3rd time
does any1 know what this means about the check engine light and feeling like it wants to shut off?all opioins matter,thanks!
Old Nov 20, 2011
only a code reader can tell you whats wrong and most auto stores check it for free.
Old Nov 20, 2011
CIVIC CITY's Avatar
:cel:yea ive called pepboys and charge $90.00 and the other auto places and they charge $.but thanks though.didnt have this problem till i took it to the this place and had the oil changed.
Old Nov 20, 2011
CIVIC CITY's Avatar
qucik ? im new on this how do u get ur points higher the blue bar the green bar and ur rep.pwr?
Old Nov 20, 2011
by posting more and how much time you spend on the site. autozone and oreilly scan it for free. or you can buy a code scanner for $40 on ebay and check yourself.
Old Nov 23, 2011
DannyK35's Avatar
I'm bigger than you.
DannyK35 is a name known to allDannyK35 is a name known to allDannyK35 is a name known to allDannyK35 is a name known to allDannyK35 is a name known to allDannyK35 is a name known to allDannyK35 is a name known to allDannyK35 is a name known to all
what he said.
Just go to either of those shops and ask to borrow the ODB. Plug it in and let the scan run & write down the codes. Then come back here as there is a thread dedicated to all of the codes. Then ask Gearbox what to do because well, he pretty much knows everything there is to know about these cars.
Old Nov 24, 2011
lazlong's Avatar
Sounds like you're new timing belt is off time. Very common problem when doing a timing belt change
Xuhme
21
Aug 7, 2023 03:40 PM
hernandexz
Oct 28, 2021 10:52 PM
tylerginevan
Apr 27, 2015 12:29 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
bahena08
Apr 11, 2015 05:09 PM
