Cooling Fan noise
Old Oct 22, 2011
bbrears's Avatar
bbrears is an unknown quantity at this point
Cooling Fan noise
I recently changed the timing belt, tensioner and water pump. Also changed all drive belts at this time. everything was fine for a couple months and now there is a very loud squeling sound when the cooling fan kicks in. Seems to happen when it is cooler outside. Thinking it may be bearing?? Any suggestions on how to confirm? Car is also miles from me now so I need to talk my son through this.
Old Oct 22, 2011
Re: Cooling Fan noise
the fans are electric, so they are not related to the belts you changed. usually fan noise means the motor is going bad. now if the squealing only happens when you turn the a/c on, that means the shared a/c and alternator belt is not properly tensioned (too loose or too tight). new belts do need to break in and their tightness will change as it gets old, so usually they need to be adjusted again down the road after the initial install. the timing belt has its own auto tensioner, but not the accessory belts.
Old Oct 22, 2011
bbrears's Avatar
Thanks. will check with him and see if he has the a/c on when this occurs.
Old Oct 22, 2011
anibis's Avatar
anibis will become famous soon enoughanibis will become famous soon enough
Yeah belts tend to loosen up after they get broken in.
I hate the wing nut tensioner b/c it can be a pain, but also love its simplicity.
Old Oct 23, 2011
yeah i once had one of those bolts or wingnuts almost back out completely and it was squealing like crazy. the shop said if i waited any longer the alt may have fallen out of its place.
Old Nov 5, 2011
bbrears's Avatar
Looks like it was the belts. Service guy said he put new belts on to the same tension and squeking went away. Perhaps I had the belts too tight initially???
7thgensurvivor
38
Aug 29, 2015 11:50 AM
lilrob1213
37
Jun 29, 2015 06:45 PM
Bruce.Ringler
Jun 18, 2015 08:12 AM
Sarahwv2910
22
Jun 17, 2015 12:35 PM
black2k1vtec
Canada West
Jan 22, 2002 07:13 PM
