constant honk after short
Old Oct 9, 2011
shteeve03's Avatar
shteeve03 is an unknown quantity at this point
ok so i have a 2004 EX and while removing the alternator i shorted while removing the little nut holding the the wire and ever since, when the battery terminal is connected, the horn does not stop sounding and it is a constant honk. does anyone know how i can fix this?
Old Oct 9, 2011
CraigW's Avatar
Re: constant honk after short
Pull the horn relay ???
Old Oct 9, 2011
lazlong's Avatar
You either burnt up the relay (under-hood fuse/relay box)or the switch (in the steering wheel), or melted some insulation along the wire somewhere causing a short to ground.
Pull the relay and test it. If it's good, inspect the fuse/relay box back and front along with the wires and connector. Then pull the steering column covers and inspect the wires and connectors. If they look good you'll have to pull the airbag to access and inspect the horn switch.
*If you're unsure about pulling the airbag post back and I'll guide you thru it, it's super easy. For that matter if unsure about any of it post back and I'll walk ya thru it.
h4ldol
Apr 24, 2017 08:16 PM
68camerors
Sep 24, 2015 06:18 PM
Jrosa
Sep 14, 2015 08:24 PM
First Car
Sep 8, 2015 08:54 PM
