Whirring sound that changes with speed (detailed information included)
Re: Whirring sound that changes with speed (detailed information included)
If it is the bearing, I have two extra rear ABS bearings I did not end up using from RockAuto. My problem was treadware, a deep line about 1/2 deep in the center tread that went for a foot. Super cheap BCT (Beijing Corp Tire?) brand though too . Same part number for my 01 EX and your 03 EX. PM me if you want one for cheap, they are sitting in their box in the garage.
Either way here is a great DIY from a member at hondacivicforum.com:
[autostream]http://autostream.com/ibcivicforums/?page_type=firebirdplayerthumbnail&framepage=1070& transactionid=1319569085-21617018105&posted_by=beastyben1_www.civicforums.c om&youtube_video_id=SyeekUF-LyE[/autostream]
Thanks for the offer and the link beastyben1. On Friday I'm opening up the drum to check things out. A part of me thinks something is up with the brake. When I try to stop the car with the e-brake there is a horrible wailing noise. Either way, brakes or bearing, I need to open the drum to check things out.
I appreciate all the suggestions.
Kenny the Ricer
Glad everythings good though.
Haha...no...not 2 months...just been lazy and getting to it
Wasn't doing much else during the nor'easter power outage and the noise was finally starting to get to me.
Wasn't doing much else during the nor'easter power outage and the noise was finally starting to get to me. Re: Whirring sound that changes with speed (detailed information included)
I've had that same problem with my 2007 Civic-EX. The first set of tires (Bridgestone=GARBAGE) were noisy as hell until I replaced them with the Michelins I have now. Then it got real quiet..now 30K miles later I have the same problem. It resonates in the trunk and gets a lot louder at highway speeds. Rotating the tires didnt help. Last night I took the brakes, rotors, and hubs off the back but the bearings seem to function OK. I'm going to go to the auto parts store to see what they think.
Common problem.
Read this thread: https://www.civicforums.com/forums/1...trol-arms.html
Read the bulletin I linked in my first reply.
Once a tire has started getting the chop, all you can do is live with it until it is worn out, or replace it. It will almost never shut up on its own, no matter what. (It might for me though, because that's how I roll. LOL)
HTH
edspyhill09
Jun 12, 2016 02:45 PM
GolNat
Sep 10, 2015 08:25 PM
Tim1959
Jun 3, 2015 08:15 PM
