2002 Civic EX lower control arm / bushing replacement
Old Aug 13, 2011
alpinemtnbiker's Avatar
alpinemtnbiker is an unknown quantity at this point
OK I have a 2002 Civic EX sedan with 182k on it. Over the last few months it's been making a clunking sound whenever I go over bumps / enter driveways / speed bumps etc... I had a friend replace my front brake pads yesterday and he told me that the noise was failing LCA bushings... They definately showed some crackage and shoujld be replaced.
Anyway....I am wondering if this is a relatively easy DIY kind of job? Looks like it can be a PITA to replace the bushings without some major shop equipment, but what about just swapping the entire LCA for new ones? How difficult of a DIY is that? From what I have googled, I don't think that an alignment is necessary if I am just changing the LCA's. The car drives great, even at high speeds, shows no uneven tire wear, no wierd vibrations, etc... It's just that clunking sound that comes from the front end. At first it was coming from the driver's side and now both sides, depending on which wheel is hitting the bumpr first.
Thanks....Adam
Old Aug 13, 2011
Re: 2002 Civic EX lower control arm / bushing replacement
any time you change suspension parts, you need an alignment. if you are going to take the lca out and do it that way, you can take the old lca and new bushings to a shop and they will only charge you to press in the new bushings ($40 maybe for all 4).
Old Aug 13, 2011
lazlong's Avatar
You have to press the balljoint in also.
Old Aug 13, 2011
i know they have tool kits for some of this stuff they rent at certain auto stores. if you know your way around cars, it may be better. its real easy to damage parts taking them out.
Old Aug 14, 2011
ball joint - if they does not have play, you could keep them, although from mileage... They will require removing the knuckle too...
Yes, I simply did swap whole assembly and kept one of the good arms so i can simply take them to the machine shop to remove/install them. (the other arms was cracked, unfortunately.
4 bolts. 2 to frame, 1 for endlink, and follow utube way to remove ball joint.
then align - you never know if older arms were slightly bent and aligned with it.
Old Aug 14, 2011
are the ball joints usually done at the same time as the LCA's/bushings?
BTW....thanks for the replies...
Old Aug 14, 2011
lazlong's Avatar
^^ Usually yes but, if the balljoints show ANY signs of wear I would replace them as they are very critical to the wheel assembly not falling apart while driving and possibly killing yourself or others.
Old Aug 14, 2011
yeah like every other suspension part. i think if i end up keeping this car much longer, im having everything replaced with new stuff. i always get that feeling in the back of my head that something might be loose or about to fall out.
Old Aug 14, 2011
lazlong's Avatar
lol. Like everytime I shift and the engine mounts POP.
Old Aug 16, 2011
OK...so I took the car into the dealer for the air bag recall and asked them to checkout the entire suspension. They said that everything was OK except for the LCA bushings and quoted me a price of $455 ($405 + tax and enviormental crap)....I went ahead and had them do it. Car drives great.....no more knocks when driving over bumps. I have a guy that has done work before on my Honda's and he said he would do it for $300 + parts. I am just glad it's done....hard to believe the car has 182k on it and drives as good as it does...
Old Aug 19, 2011
ZFreak's Avatar
Honda Crazy
ZFreak is an unknown quantity at this point
Outstanding. There were definitely cheaper ways to go about fixing it. If you hear the noise return soon, the only other possibilities are upper strut mounts, ball joints, and front sway bar links. Enjoy.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
CarStuff
Dec 6, 2020 12:52 PM
usajags84
May 10, 2015 08:11 AM
bsmiley
Apr 27, 2015 01:27 PM
smmahan
Apr 15, 2015 08:17 PM
