Power door lock problem.
Old Aug 7, 2011
jc102800's Avatar
jc102800 is an unknown quantity at this point
My drivers side rear power door lock stopped working a few days ago. I figured it was the actuator so I went and got a new one and put it on. I checked the signal voltage at the pigtail in the door and I am getting one volt or less. I checked the voltage at the multiplex control and got the same thing. I don't know if this is voltage it is supposed to have. My three other doors work just fine. I check the fuse and they are fine. Is there a relay or something else that could have wed bad? Any help would be appreciated. Thank you. Josh
Old Aug 8, 2011
CraigW's Avatar
Re: Power door lock problem.
Broken wire, open connection.
What year ?
roverben
Jan 21, 2019 05:16 PM
h4ldol
Jun 3, 2015 03:26 PM
MamaBear2015
May 3, 2015 02:17 PM
darwin-t
Apr 18, 2015 09:29 PM
NoToRiOuSxPiNoY
Bolt-on Engine Performance
Nov 7, 2001 11:19 PM
