d17a2 block z6 head in a o3 ex
Old Aug 1, 2011
Bustitsideways's Avatar
Bustitsideways is an unknown quantity at this point
d17a2 block z6 head in a o3 ex. Iknow the head will bolt on the block but my question is what about all the sensors on the intake mani and the cam timming stuff behind the cam gear on the stock a2 will it work on the z6?
The car hopefully will keep the stock ecu and obd 2.
I am doing this cause the d17a2 head sucks has small ports and the head flange for intake mani and exhaust sucks ***, there is nothing for it. The z6 on the other hand has everything going for it, not o mention the d16 and d17 blocks are almost identical.
Question is will it work cause if it will ill make a diy and post it up. i just need to make sure about the electronics.
Also assuming this will work cam i use the d17a2 cam in the z6 head to keep the a2 electronics?
MichaelLW
Sep 14, 2015 07:15 AM
7thgensurvivor
33
Sep 5, 2015 08:20 PM
JetsterDajet
Aug 15, 2015 08:07 AM
Valkman
Aug 13, 2015 04:19 PM
USCGBM
Aug 12, 2015 04:22 PM
