TPS mythos, need pic and assistance..
Old Jul 25, 2011
Daguls's Avatar
Daguls is an unknown quantity at this point
Can someone post a pic of stock tps bolts on an 01 ex tb?
I will do the same, and would like if someone could confirm either it being stock or aftermarket.
Going to take the pic now...phone doesnt connect to web anymore, so I'll have to usb, gonna take a couple minutes...figured I'd get a headstart on a pic from you guys..brb.
Old Jul 25, 2011
Daguls's Avatar
Re: TPS mythos, need pic and assistance..
aaaaaaand my g/f has my usb cable at work right now...
I'll post it later, but still, anyone got a pic? I'm looking for the bolts themselves. or rivets, or headless bolts, or whatever you want to call them..I have tried searching the web and here but havnt found a photo that clearly shows the bolts.
Old Jul 25, 2011
they are rivets, need to be drilled out to remove and cannot be used again. you have to tap and thread new holes and use screws/bolts. not the best pic but all it has are two metal knub looking rivets.
Old Jul 25, 2011
Daguls's Avatar
This is what mine looks like...does the tps and bolts look stock?
:edit: the tps bolts are all I really care about...I'm also just trying to figure out if the tb/tps were ever replaced before.
Old Aug 8, 2011
Daguls's Avatar
btw, the other reason i was wondering is because i didnt have to do anything to mine to get to adjust it. needle nose around the outside edges of the "rivets" and they turned after a little force. they tighten and un-tighten perfectly. if this is to be said about all of them, then I think I've found an easier way to adjust and instal the tps...
can someone confirm this?
Old Aug 8, 2011
pics look stock to me, but the rivets shouldnt be loosening like that. if you moved the sensor even 1mm, it will wack out the car. it takes very precise measurements to properly position it by reading voltage outputs. even honda will not mess with it and recommend to replace the whole throttle body. they do not sell the sensors separately. what is your issue tho that you need to adjust it? if it went bad, i would recommend a used $50 tb off ebay and swap the whole thing. tps is too much of a pain to play around with.
ricer_em2
May 11, 2016 08:09 PM
Tyler93
Mar 20, 2016 09:03 PM
thatcham
Sep 30, 2015 08:28 AM
Matt T
Idle Issues
Sep 24, 2015 04:53 AM
thaler4cuse
Sep 7, 2015 08:25 PM
