AC Not Blowing Air
Old Jun 9, 2011
garden772's Avatar
2001 Civic LX
garden772 is an unknown quantity at this point
AC Not Blowing Air
Well,for a while now my civic has not been blowing out any Air at all. I checked all the fuses everything is ok. I was scanning around under the hood and found this little black cylindrical box thing around where I believe is the AC Fan. Its connections is a little weak but I dont know what it is so I was hoping somebody could tell me what it is. I snapped a couple photos of it. I also checked the AC Filters to see if that could be it but even w/o the filers installed still no air. I don't know which fan is which on the grill but both of them were operating so they couldn't have gone bad.I really badly need AC its been touching 100degrees Farenheit this whole week. I am a big DIYer so i would rather do it on my own than take it to a shop.
-Please Help,Thank You
Old Jun 9, 2011
johndeerebones's Avatar
johndeerebones is a jewel in the roughjohndeerebones is a jewel in the roughjohndeerebones is a jewel in the rough
Re: AC Not Blowing Air
Its not under the hood. It is in the same area as the filters are. Its accessed from the passenger's footwell.
Old Jun 10, 2011
CraigW's Avatar
Search the transistor threads here.
Try this, with the cabin filter out look in on the blower fan and see if it trys to turn a tiny bit when the blower switch is 1st turned on (key at II)
Old Jun 12, 2011
val15's Avatar
val15 is an unknown quantity at this point
Sorry for cutting in on the thread but that happens to my fan, I turn on my car everything runs for 2 seconds then it turns off. I had a mechanic take out the fan and it tries to spin just a bit as I turn it on. Are you able to help me?
Old Jun 12, 2011
CraigW's Avatar
01-05 ?????
If so... possible open TCO on the transistor assembly.
Old Jun 12, 2011
val15's Avatar
01-05 ?????
It's a 2002 Honda Civic EX... Welll, I'm not sure what you are asking for, I know what transistors are but not sure where that would be. Where would this be located?
Old Jun 13, 2011
CraigW's Avatar
The transistor is mounted under the dash close to blower fan and in the airstream of the blower fan to help cool it.
If you have never changed the cabin filter the transistor unit can get hot enough to open the TCO. You can either locate the open tco and replace it or simply replace the transistor assembly as a unit.
Here is a link that may help. Don't use a resistor as a replacement. Find the correct size tco or replace the assembly.
https://www.civicforums.com/forums/3...ght=transistor
Old Jun 13, 2011
val15's Avatar
you say not to replace it with a resistor but in this tutorial it shows them adding a 1ohm resistor in parallel to make this work. So i just add that one resistor or replace the whole thing? I think I'll be able to do this though, I have a good amount of experience with electrical soldering.
Old Jun 13, 2011
val15's Avatar
Talking Re: AC Not Blowing Air
It worked, THANK YOU SOOOOO MUCH. I was worried i was going to have to spend over 500 dollars to get it fixed. I went and bought a soldering kit and a 1ohm resistor and it worked!!! I appreciate your help and everyone who contributes to this website.
Old Jun 14, 2011
CraigW's Avatar
FYI the TCO you replaced is a safety part.
That is not my diy... and not the part I would have used.
I suggest you get the TCO and do it properly.
These are TCO devices: http://www.cantherm.com/products/thermal_fuses/sdf.html
Old Sep 15, 2020
Walt Dittrich's Avatar
Walt Dittrich is an unknown quantity at this point
Can anyone please tell me what TCO means or is?
Thank you! 🙏🏻
(Sorry to sound ignorant, but if one doesn't ask, they'll never know. And a Google search didn't turn up anything. &#128546
NoobyKid
Jul 13, 2015 07:53 AM
ZILLA
Air Conditioning
Jul 11, 2015 08:35 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
