Non mechanical till Comp blows...
Old Jun 2, 2011
s0yp0p's Avatar
s0yp0p is an unknown quantity at this point
Driving 01 ex with the weirdest issue: the heater creates problems. They linger for following days until the computer clears it. The check engine light does not go on. . .but it's electrical.
So:
Driving down 3 miles here the electronics start clicking... causing abs to go off and roll into a horrible degrading stop. I've changed crank and cam sensor so I'm lost on what to change.
All of the electrical is OUT. Like the car sat with lights on for 2 days. Nothing is responsive for a few minutes. Then, it turns back on. Conserving energy I avoid red lights, signals, making me a threat to society in the car.
A friend of ours said the starting solenoid but i've never had issues initially turning the car on. It's while it is moving it will error. Never before.
It's odd because it did this in December. . . didn't drive till February. It was fine then it starts again 4 months later. Ideas?
Old Jun 3, 2011
BlueEM2's Avatar
Whachya lookin at?
Re: Non mechanical till Comp blows...
Might not be grounding properly. Check all your grounds to make sure they are firmly attached to a clean piece of exposed steel. They could be corroded or who knows. Also check the wires to make sure they are intact etc. Could be the problem since it`s intermittent.
suburbanite
Jul 17, 2015 03:05 PM
Roman Rembacz
Jul 16, 2015 12:30 PM
krazykoncepts
Jul 14, 2015 01:55 PM
phantommaggot
Engine start problems
Jul 12, 2015 12:55 PM
ballmich
Jul 9, 2015 11:59 AM
