Diagnosing potential A/C system leak
Old May 22, 2011
BiggSean's Avatar
BiggSean is an unknown quantity at this point
Hey guys, I suspect that I have a leak in my A/C system.
I have a 2005 Special Edition with approximately 107,000 miles on it.
It has worked well for the past few months since I purchased the vehicle. On Friday, the A/C system abruptly stopped working on my way home from work.
When I got home I confirmed that the compressor was turning on/off with the A/C button. I happened to have a can of R134 handy, so I recharged the system and it started to work again. Flash forward to this afternoon, I decided to see if it still worked. I started the car, and the compressor would not turn on, nor would the fans.
To rule out the pressure switch, I unplugged it and jumped the terminals. The compressor and fans came right on. I let it run for a few minutes with the jumper in place, and the car blew nothing but hot air.
I suspect that there is a leak somewhere in the system, hence they reason why my compressor and fans fail to turn on via the pressure switch.
What is the best way to self-diagnose where the leak could be coming from? Are there any common components that go bad with a car of my mileage?
Old May 22, 2011
green01civic's Avatar
green01civic will become famous soon enoughgreen01civic will become famous soon enough
Re: Diagnosing potential A/C system leak
Do you have a real set of manifold gauges, or just the dinky can tap hose gauge, or no gauge at all and just a filler tube for your can?
To check for a leak, you could charge it with dye and hit it with a UV light (yellow tinted UV goggles help, for contrast sake).
Old May 22, 2011
BiggSean's Avatar
Originally Posted by green01civic
Do you have a real set of manifold gauges, or just the dinky can tap hose, or no gauge at all and just a filler tube for your can?
I don't have a set of manifold gauges, I used a kit that included an in-line gauge.
Old May 22, 2011
Was the compressor on and running when you checked and charged it?
Old May 22, 2011
BiggSean's Avatar
Yes, motor was running and compressor was spinning.
As I said, during the recharge process it started to blow cold air again.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
Jro773
Jun 9, 2015 06:38 PM
g4384063
May 30, 2015 11:21 AM
dinsum
May 28, 2015 09:30 PM
htowncivicEX
Jan 21, 2002 11:48 AM
