Advice on Spark Plugs for the D17A2
Old May 12, 2011
MarkoPollo's Avatar
MarkoPollo is an unknown quantity at this point
Just wondering if you folks can share you thoughts. I just purchased a set of NGK ZFR6FIX-11 Iridium IX and will be installing them in the next week.
I was thinking that I probably should have asked for advice before hand, but this thread might help someone down the line.
D17A2 VTEC
  • Found in:
    • 2001-2005 Honda Civic EX (US only)
    • 2001-2005 Honda Civic LX (Europe)
    • 2001-2005 Honda Civic Si (Canada only)
    • 2001-2005 Acura 1.7 EL (Canada only)
    • 2000-2007 Honda Stream 1.7 (Japan)
      • Displacement : 1,668 cc (101.8 cu in)
      • Bore and Stroke : 74.98 × 94.4 mm (2.952 × 3.72 in)
      • Rod Length : 137 mm
      • Rod/Stroke : 1.48
      • Compression : 9.9:1
      • Power : 127 hp (94.7 kW, 132 ps) @ 6300 rpm
      • Torque : 114 ft·lbf (114 ft·lbf USDM) (15.8 kg/m, 155 Nm) @ 4800 rpm
      • RPM redline: 6800 rpm
      • Rev-limiter : 7200 rpm
      • Valvetrain : SOHC VTEC (4 valves per cylinder)
      • VTEC Switchover : 4500 rpm
      • Fuel Control : OBD-2 MPFI
Old May 12, 2011
MelJ's Avatar
Trance Addict
Re: Advice on Spark Plugs for the D17A2
Make sure they're properly gapped before you put them in.
Old May 12, 2011
MindBomber's Avatar
Live for the Twisties
Those are the same plugs I have and they perform excellent. Did you have a specific question on them or just want to if they're generally good plugs?
Old May 13, 2011
Biscuit's Avatar
2001 Civic LX Sedan
Biscuit will become famous soon enoughBiscuit will become famous soon enough
I like them. 100K plugs are nice. Just have to pull them once a year to check the condition and gap.
Old May 13, 2011
100k for iridium? more like 30k tops even denso recommends this for their iridium. platinum is the plug with longer life.
Old May 13, 2011
MarkoPollo's Avatar
I don't know if i'll try to get 100k out of them. the gap is 0.4 right?
Old May 13, 2011
green01civic's Avatar
green01civic will become famous soon enoughgreen01civic will become famous soon enough
the laser iridium can go up to 100k, but not iridium ix. the laser iridium has a platinum ground, ix doesn't. (unfortunately the laser iridium doesn't come in a config for our civics).
if you do gap the iridium plug (which no manufacturer I know of recommends doing) be extra careful with the iridium tip...
Old May 13, 2011
D17A2 VTEC
  • Found in:
      • Bore and Stroke : 74.98 %u00D7 94.4 mm (2.952 %u00D7 3.72 in)
      • Rod/Stroke : 1.48
      • Torque : 114 ft%u00B7lbf (114 ft%u00B7lbf USDM) (15.8 kg/m, 155 Nm) @ 4800 rpm
?!? WTF the engine specs have to do here? Where is the actual question?
Old May 13, 2011
MarkoPollo's Avatar
Because not all civics have the same engine. There might be better plug options for different engines, and sometimes people outside of Canada get confused when you talk about an Si Coupe. I stated the engine to get the most precise answer.
And in case someone down the line want to do a search on the topic, chances are the specs will provide a good hit and help them out.
That's WTF yo.
Old May 13, 2011
did you see my sig? yo! engine codes, among others.
Old May 14, 2011
BlueEM2's Avatar
Whachya lookin at?
^Time to take a deep breath again sdai
Old May 14, 2011
pheeew, took my breath, solved a small detonation trouble, and back to do what need to be done.
Check list:
- not out of place
- no big troubles in the thread
- was trying to give more info
was just hard to understand, is all.
So, apologies - have been a hectic day since yesterday with several misplaced threads and 2 guys in a row reviving 2008 dated threads for nothing.
I had me head hot, so apologies again.
Old May 14, 2011
MarkoPollo's Avatar
NGK States that there is a laser plug for the application. Maybe it's new?
Spark Plug
Part No.
Plug Gap
V-Power ZFR6F-11
.044
G-Power ZFR6FGP
.044
Laser Platinum PZFR6F-11
.044
Iridium IX ZFR6FIX-11
.044
Old May 14, 2011
MarkoPollo's Avatar
Anyone out there have experience with the Bosch Platinum Fusion? p/n 4501? The four electrodes look pretty mean, don't know how they would perform though. It looks hella hot.
http://http://www.boschautoparts.com/sparkplugs/Pages/PlatinumIrFusion.aspx
Old May 14, 2011
Nah, you're looking at the wrong plug. That's a laser platinum (a very good plug, will give you very long life).
Iridium IX = Iridium Tip, Nickel Ground
Laser Platinum = Platinum Tip, Platinum Ground
Laser Iridium = Iridium Tip, Platinum Ground
The "Laser" series will give you the longest life, and the Iridium version is the highest performing. I've only ever used NGK plugs in my cars, and have been happy with them, so I can't comment on anything else.
Old May 14, 2011
MarkoPollo's Avatar
Performance is what I am looking for, thanks for the info!
Old May 14, 2011
anything but ngk or denso is junk in hondas.
Old Feb 22, 2016
Steven Eisler's Avatar
Steven Eisler is an unknown quantity at this point
Nickel or Platinum ground in Iridium for highest performance?
Cheers
Old Oct 10, 2016
mclean987's Avatar
mclean987 is an unknown quantity at this point
Cheers
bump
ever get an answer for this ? i would like to know and for turbo applications which is better anyone ?
MamaBear2015
Jul 3, 2015 11:26 PM
danace99
23
Jun 28, 2015 08:49 AM
JohnnyBxo
16
May 9, 2015 05:53 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
MikeyBoy
Jan 26, 2002 06:45 AM
