03 civic won't run
Old May 7, 2011
gdenine's Avatar
gdenine is an unknown quantity at this point
03 civic won't run
replaced head gasket , timing belt and water pump. the car ran fine before repairs, but now it starts up right away and shuts down in a second or two.
Old May 7, 2011
Re: 03 civic won't run
timing is off?
Old May 7, 2011
gdenine's Avatar
i did not remove the crank sensor just the plug , wil this cause a problem
Old May 7, 2011
i meant timing as in the marks werent lined up properly. crank sensor coudlve been damaged if you spilled any fluid on it. is the engine light on? check the codes too.
Old May 7, 2011
gdenine's Avatar
the timing marks look good but the procedure for timing belt replacement says to remove the sensor , does anybody know why. maybe this is my problem. how would i know for certain
vtec92
May 4, 2017 03:20 AM
usajags84
15
Aug 19, 2015 03:12 AM
Trav_02civic
Engine start problems
Apr 23, 2015 08:57 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
