Does my car have an alarm or what is this?
Old Apr 15, 2011
DH757's Avatar
DH757 is an unknown quantity at this point
Question Does my car have an alarm or what is this?
I've been wondering if my car should've come with an alarm.
I have the keyless entry remote with UNLOCK, LOCK and PANIC mode only.
However there's a strange red light under my Cruise Control and Mirror switch that doesn't light up at all. It's connected to something underneath the dashboard/steering wheel; you can see the cable there.
Could this be the alarm? There's no sticker on my window either that notifies that there is one. Could it be disabled? How can I reactivate it, if it is?
Old Apr 15, 2011
Re: Does my car have an alarm or what is this?
prolly a factory alarm, which is a small box that plugs in under the dash where you describe. comes with a led light too and works with the keyless remote. go inside your car and press the lock button on the remote. then manually lift the lock of one door and open it. if nothing happens, you just have keyless. if the horn starts honking, you have the factory honda alarm accessory.
Old Apr 16, 2011
DH757's Avatar
I stepped inside locked myself in and unlocked and opened the door.
No sound or lights.
Although the LED doesn't flash at all.
Does the alarm need a battery or a fuse to work?
Old Apr 16, 2011
if its oem honda alarm, no. its just a module that plugs into the stock wiring under the dash. if its aftermarket, yeah it requires alot of wiring to get it working and a fused power wire to the battery. its possible someone before you had an alarm and decided to remove it.
usajags84
15
Aug 19, 2015 03:12 AM
ChristinaVHH
May 10, 2015 03:51 PM
Linda0818
Apr 23, 2015 11:30 AM
JjAnGPeETuL
Nov 8, 2001 06:37 AM
ChiFroBoy
Oct 24, 2001 01:32 AM
