shifting trouble, need help asap...
Old Mar 14, 2011
mc670's Avatar
mc670 is an unknown quantity at this point
so on my way to work today i noticed my shifter feeling a little bit loose/yest tough to shift and hard to find the gears. i took out my center console to investigate the shifter cables, and everything appears to be fine.. but the biggest and strangest problem im finding is that if you pull the shifter down to 2nd, 4th or reverse gear, you can pull the gear stick back further than its supposed to it seems, putting the tranny in neutral.. you can wiggle the gear stick just like its normally in neutral... yet its pulled all the way back where its supposed to be 2nd, 4th, or reverse..
Sorry if it sounds really confusing, but it really got me bugged. i can hardly find reverse with the shifter messed up. has anyone else had this problem?
Old Mar 15, 2011
mc670's Avatar
Re: shifting trouble, need help asap...
anyone!? i did some searching.. post #2 in this old topic i found almost sounds like my problem.. but has anyone ever had a problem similar to mine?
https://www.civicforums.com/forums/3...er-issues.html
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
ricer_em2
May 11, 2016 08:09 PM
sesi
Oct 1, 2015 02:03 PM
Nalmonte
Sep 28, 2015 01:10 PM
Bruce2
Sep 27, 2015 08:45 PM
