Idle off...-_-"
Old Mar 6, 2011
sdaugh7261's Avatar
sdaugh7261 is an unknown quantity at this point
Angry Idle off...-_-"
So, I have a 2001 Civic LX, 200,600 Miles on it Just recently had the Head Gasket blown so it was replaced by a shade tree mechanic. Well when he put it back together he did not bolt the alternator down all the way and apparently Honda decided to ground the alternator via the bolts that connect to the Engine Block. Little know fact if the bolt is even a little loose it will fry you computer. so he frys my computer and then sends it to a Honda dealer who put in a new one. Now I'm having to issues that make me want to kill someone.
1. Well flooring it to get onto the interstate the engine maxed out at 70mph at 7000rpm and It would not shift up it just held that way, so i had to let off and give it time to shift and then reapply throttle.
2. If I take a long trip when I come to a stop the engine will idle at about 500-800rpm or it just stalls out. I tried to shift to N to see if that would help, no luck still stalls or it fights with itself to stay on, or I have to rev it up and hold it. I just changed the plugs prior to the gasket issue so I was wondering, could this be a Idle Air Control Valve issue?
Old Mar 6, 2011
2005civiclx's Avatar
2005civiclx is a jewel in the rough2005civiclx is a jewel in the rough2005civiclx is a jewel in the rough
Re: Idle off...-_-"
have you done the idle learn procedure yet? if you got a new computer then your car probably doesnt know its idle yet and thats why its dying
Old Mar 6, 2011
sdaugh7261's Avatar
Re: Idle off...-_-"
Please explain.....I'm tired of it dying
Old Mar 6, 2011
Re: Idle off...-_-"
disconnect your battery for about 20 seconds. then connect it and turn your car on and let it idle for 10 minutes with everything off and give it gas when it seems its about to die but not too much just get it back up to normal idle and then after the ten minutes turn your car off and turn it back on for about 5 minutes. if this doesnt fix it then its something else but its always good to check this out first cause its free.
Old Mar 6, 2011
sdaugh7261's Avatar
Re: Idle off...-_-"
Now if I'm just driving around town nothing happens?, would this still be the learn function?
also, what is normal idle rpms?
Old Mar 7, 2011
Re: Idle off...-_-"
my lx idles at about 750-800. if it doesnt learn its idle then its something else. before you blew your head gasket was your car running well?
Old Mar 7, 2011
sdaugh7261's Avatar
Re: Idle off...-_-"
Perfectly, except the oil in the coolant system.
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
RSKtakR
25
Sep 14, 2015 07:43 PM
2.0.0.2
Sep 14, 2015 06:38 PM
MichaelLW
Sep 14, 2015 07:15 AM
SolidHollow
15
Sep 13, 2015 11:18 AM
