02 ex auto trans slipping
Old Jan 12, 2011
toonlovescheryl's Avatar
toonlovescheryl is an unknown quantity at this point
My transmission is beginning to slip horribly when changing through the first three gears. When I went to the transmission shops in my area, I was told that it was going to cost three thousand dollars to have it replaced by just about every shop in town. But I was told if I had my own transmission, it would only cost 400 bucks to swap my old transmission with the new one. I do not want to buy a used tranny from the junk yard cause I dont want to take the chance of running into the same problem with it failing. Can someone please inform me of where I can purchase a remanufactured complete automatic transmission with torque converter besides from at the dealership?
Old Jan 12, 2011
Re: 02 ex auto trans slipping
usually rebuilt trans arent sold separately, they are done by the shop. and they are done very sloppy, just replacing a few parts that look like they went bad. the proper way (which most mechanics never do) is a complete rebuild by replacing all the parts (clutches, seals, filter, etc). TCI is the only good rebuild kit i recommend. if you can find a mechanic that will use the kit and rebuild yours, thats really the only option i recommend. if not, swap in an rsx motor with manual trans. these defective autos arent worth the time to fix or replace anymore. taking it to a regular transmission shop and saying "fix this" will likely result in you coming back two months later with another blown trans.
http://www.compperformancegroupstore...ngOverhaulKits
juror
Suspension DIY
Jul 30, 2019 03:28 AM
0396
May 4, 2016 07:14 AM
mrohitredd
Aug 12, 2015 11:36 AM
Dangerousjordan
Jul 27, 2015 03:43 PM
Jul 12, 2015 11:54 AM
