Key Won't Go Into Driver's Side Keyhole
Old Jan 1, 2011
03CivicLXSilver's Avatar
03CivicLXSilver is an unknown quantity at this point
I bought my car used 2 years ago and back then I had difficulties sometimes getting the key into the hole but it would eventually go in if I flipped it over or tried a little different angle or something.
As of a couple weeks ago, my key will not even go in half way. I cannot insert the key into the hole. I have to unlock the passenger's side door and crawl over and unlock the driver's side by hand from the inside. Otherwise the lock works; it keeps people (including those with a key!) out.
The only thing I've tried was focing that red straw that comes with WD-40 into the hole and spraying some in there.
Does anyone have any suggestions?
Thanks.
Old Jan 1, 2011
Re: Key Won't Go Into Driver's Side Keyhole
prolly need to take the door panel off and spray silicone lube (not wd40) from the back onto the moving parts as you play with the handle and key turning.
Old Jan 1, 2011
TiggerDX's Avatar
TiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of light
Shooting some Graphite powder in the key hole may help as well.
Taking the door panel off will be the best way to get in there and clean it up and lube it well though.
Old Jan 2, 2011
Biscuit's Avatar
2001 Civic LX Sedan
Biscuit will become famous soon enoughBiscuit will become famous soon enough
If you have kids ask what was stuck in there. If no luck with that there could be a toothpick or a twig in there.
It sounds crazy but my youngest girl stuck a twig into the pass door lock and I had the same problems.
The fix was using my Craftsman assorted picks to remove the wood from the lock and some Aerokroil after.
Nathan
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
Poopies
Apr 20, 2017 11:36 PM
Youshoe
May 22, 2015 09:36 PM
MamaBear2015
May 18, 2015 07:37 PM
johnnieblazze
Dec 6, 2001 03:07 PM
