Burned out moon roof bulb
Old Nov 23, 2010
Mano and Kim's Avatar
Mano and Kim is an unknown quantity at this point
I want to change this bulb, as it is either loose or finally burned out. Just don't want to scratch up the console doing it. How do I get to this little bulb behind the power moon roof button?
Old Nov 24, 2010
CraigW's Avatar
Re: Burned out moon roof bulb
iirc the coin box has a single screw to remove it and switch bezel.
The bulb is in a plastic socket. Use a small flat blade and twist left for removal.
Get oem # and pick up at dealer $3-$4
Old Nov 24, 2010
also make sure you get the proper color for your car. sedans use bulb with green cover, coupes have orange cover.
Old Nov 24, 2010
Excellent guys..thanks!
Old Nov 24, 2010
Kennykid2002's Avatar
Kenny the Ricer
Curious, since i've never taken it apart...
But shouldnt it be just the same bulb with a green plastic filter?
Old Nov 24, 2010
the bulb has a color condom on it. either green or orange for the cruise/roof/mirror/fog/defrost buttons that go on the lower left side above the coin tray. the center console lights by the radio have plastic color inserts for the dials and buttons. gauges are painted color on the back.
UltraHDGames
Jun 8, 2016 05:16 PM
cferry7
Oct 18, 2015 06:32 PM
cferry7
Oct 3, 2015 04:33 PM
raymondxcho
Sep 29, 2015 09:00 PM
Luluharp
Sep 27, 2015 11:56 AM
