Really, REALLY, frustrated......need help.......please
Old Nov 20, 2010
chevysbest92's Avatar
chevysbest92 is an unknown quantity at this point
my fiancees 2003 civic ex has been giving us some nightmares. it started about a year ago. we wouldnt get heat at idle in the winter, and then when summer came around, it would overheat, i replaced the thermostat, was good for about a week, then same symtoms, i replaced the head gasket, it was shot, and put another new thermostat in, was good for about a month. bought a honda thermostat and put that in, now its starting to act up. i have no clue whats going on. i dont see any leaks by the waterpump/timing belt housing. i really need help guys, her inspections comming up and she has some trouble codes that need to get fixed , and that alone will cost a pretty penny, this has to be relaible for her in the winter too. ANY help would be greatly appreciated
Old Nov 20, 2010
Kennykid2002's Avatar
Kenny the Ricer
Re: Really, REALLY, frustrated......need help.......please
Hmmm, dunno, but I would check your radiator fluid
Old Nov 20, 2010
MelJ's Avatar
Trance Addict
Yeah. Could be something simple like a bad radiator cap or low coolant. Or an old radiator. Check the fins.
Old Nov 20, 2010
its going thru coolant like crazy, i keep filling and burping about every other week. i already put a new radiator cap on
Old Nov 20, 2010
Kenny the Ricer
Might have a leak somewhere, if you have a garage, keep it in the garage, put a pad of newspaper under your car, check in the morning to see if anything leaked
Old Nov 20, 2010
MelJ's Avatar
Trance Addict
Looses hoses? Worn hoses? Check the condition of them just to rule them out.
Old Nov 20, 2010
already ckecked, no leaks, hoses r fine
Old Nov 20, 2010
if youre losing coolant and it doesnt leak, sounds like its being burnt due to bad headgasket.
Old Nov 20, 2010
530matt's Avatar
530matt is an unknown quantity at this point
sounds like a cracked head if gasket didnt fix the issue,
did you have the head resurfaced when you did the gasket?
might be a warped head.
Old Nov 20, 2010
no cracks in the head and it was flat within tollerance
Old Nov 21, 2010
which trouble codes are being thrown?
Old Nov 21, 2010
TRIZ's Avatar
We need to know the CEL's your getting- its your car's way of telling you whats wrong with it. If its not the thermostat, its probably the switch that turns the fans on and off (since your not getting any heat at idle)
Old Nov 21, 2010
the codes have nothing to do with it, pressure valve for the fuel system and some other thing, but not related, im a mechanic, my dad was, my cousins are, and my 2 best friends are and were all at a loss, were all just scratching our heads
Old Nov 21, 2010
lazlong's Avatar
It's gotta be a headgasket or cracked head, the coolant has to go somewhere.
Edit: Could also be a cracked block. If it's cracked below the piston it would be getting in your oil. Is the oil cloudy?
