03 Power Mirror Issue
Old Oct 28, 2010
civex03's Avatar
civex03 is an unknown quantity at this point
I am having an issue w/ both power mirror functions. I can adjust them left/right no problem, but the up/down does not work on either. Is there a fuse possibly to correct this? If so, where is that located?
Thx in advance for any help/advice.
Old Oct 28, 2010
lazlong's Avatar
Re: 03 Power Mirror Issue
Naw. It's the mirror switch in the dash. #2: http://www.bkhondaparts.com/billkay/...itch=&hidIrno=
Old Oct 28, 2010
civex03's Avatar
How do I or how would I kno this for a fact? and is it the first one listed (2) in that link? I found this too..a bit more prob but is what you are referring to?
http://cgi.ebay.com/ebaymotors/01-04...Q5fAccessories
Old Oct 28, 2010
lazlong's Avatar
I looked it the service manual. There's no relay and if it was the fuse it wouldn't work at all. If it was one mirror doing this I would say it's the actuator behind the mirror but, it's happening to both so, it has to be the switch.
Yes, the one on Ebay is the same but, for the same price go down to the local Honda house and get a new one.
That is the only switch in that panel you can pry out from the front. You will see a little slot on the bottom of the switch that you can stick a small flathead in.
Erndog81
Oct 31, 2015 03:01 PM
HiImBrandon
Jun 1, 2015 07:34 AM
Paul Harsze
May 20, 2015 11:37 AM
SLeePeR012
Jan 7, 2002 12:24 AM
huyqvu
Dec 12, 2001 02:43 PM
