Power loss/bogging...
Old Oct 26, 2010
jponto07's Avatar
jponto07 is an unknown quantity at this point
Hey guys,
My '03 EX with 98K is acting up. Basically it acts like its going to die when I push the accelerator, but only in the first few minutes after start up. I just bought the car about 1000 miles ago, so I can't speak much to its history, but I've done all of the regular tune-up stuff since I purchased it.
This doesn't always happen, but if its going to happen on a particular trip, it does so immediately after start up. Pushing on the gas pedal once the idle drops only forces the RPMs lower, but if i floor it, the car takes off like a rocket.
Sometimes it even does this when shifting. If I back out of my parking space, and put it into drive, I can usually tell that the car is going to sputter. Prior to doing so, I can feel the lack of throttle response, almost like the plugs were shot and the oil was replaced with glue or something. So I go to take off, and the car is holding back as I accelerate, then when it shifts it the power just craps out. The car never stalls, but I get the feeling that it very well could.
I did get an o2 sensor code the other day(P0132) which went away after about 25 miles or so. I'm not convinced the problem is the o2 sensor due to the fact that the engine is generally cold when it does this (and the o2 sensor needs to be hot to send a signal). That being said, if the car sits for as little as 30 minutes, it might bog/stutter when I try to drive it (motor obviously still very warm).
This is really driving me crazy...any help/suggestions are greatly appreciated!
jordan1794
General 8th & 9th Gen
May 11, 2019 08:59 PM
kmarcet
Sep 26, 2015 10:25 PM
Dave1984
Jul 22, 2015 06:10 PM
breanna_17
Jul 21, 2015 04:01 PM
