Clutch Help Pleasee!
Old Oct 20, 2010
civicstew08's Avatar
civicstew08 is an unknown quantity at this point
Heyy All!
This is my first post on the civic thread.. Be nice pleassee? :P
I've just bought an 04 honda civic 1.6 sport as a 2nd car, i've never been so happy!!...
...But.. driving back home today, i was slowing down using the foot brake and then changed from 3rd gear into 2nd (in slight traffic), and on the way bringing the clutch up, i think i felt a judder in the pedal.. now is this something im imagining?? or what?
(Does it help that i have a slight noise when idling, and when i press the clutch it goes away?)
Thanks in advance!
Stew
Old Oct 20, 2010
02civicsi02's Avatar
Low and slow!
Re: Clutch Help Pleasee!
You could have some air in the line or possibly the clutch and pressure plate could be loose or the throw out bearing could be bad or something. And usually there is to different sounds when the clutch is up and the clutch is down and this is normal. But does your pedal still do this or have any other problems or is it fine now.
Old Oct 20, 2010
is there any possible way of checking for air in the line? Are all those things your mentioning dangerous or bad for my poor little car...?? lol
My pedal doesnt do that all the time, maybe like 5% of the time when im slowing down in traffic? is it just bad driving maybe..? :P
Thanks for the reply
Old Oct 20, 2010
Low and slow!
Ya just put a clear hose on the bleeder valve on the slave cylinder and loosen it and have someone pump the clutch. If there is air bubbles in the tube then there is air in it if not then you are fine. Make sure while doing this keep the reservoir full of fluid. And if the throw bearing is bad or the pressure plate is loose then yes it can cause bad things with your tranni. But since it only does it maybe 5% of the time then I dunno. It might be just you.
Old Oct 20, 2010
Ah alright, ill most certainly have a look at that..
And ill try driving abit differently? lol
Thanks very much for your help any ways!
sesi
Oct 1, 2015 02:03 PM
ThatGuy913
Sep 28, 2015 05:35 PM
speedlever
Sep 24, 2015 07:18 PM
powman02
Sep 15, 2015 07:38 PM
Klame9420
Sep 7, 2015 10:03 PM
