Idle up and down
Old Oct 4, 2010
Hondayholic's Avatar
Hondayholic is an unknown quantity at this point
Idle up and down
I have a 97 Honda 3Dr DX, 5 speed. I recently pulled my blown engine and replaced it with a low mileage 2000 engine out of an automatic DX. The only differences between the engines were the 2000 had a different plug on the distributor and the IAC was different on an automatic. I changed out the distributor plug and replaced the IAC with one from a 5 speed. The engine runs great except when it reaches running temp the idle goes up and down. I am showing no trouble codes. I installed new O2 sensors and cooling system checks out. I checked for vacuum leaks. My next step is to adjust the set idle screw. My thinking is the automatics idle is set different then a standard. Does anybody know what else it could be?
Last edited by Hondayholic; Oct 5, 2010 at 03:26 PM. Reason: Kennykid2002 thought O2 sensors was the problem.
Old Oct 4, 2010
Kennykid2002's Avatar
Kenny the Ricer
Re: Idle up and down
Idle surges could be a number of things,
With my quick 5 second searching of civicforums, i saw either O2 sensor, or bubble in coolant system
so meh...look around
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
RSKtakR
25
Sep 14, 2015 07:43 PM
2.0.0.2
Sep 14, 2015 06:38 PM
MichaelLW
Sep 14, 2015 07:15 AM
SolidHollow
15
Sep 13, 2015 11:18 AM
