94 civic vtec no check engine light
Old Sep 18, 2010
weib999x's Avatar
weib999x is an unknown quantity at this point
Question 94 civic vtec no check engine light
alright here's the deal.this car runs ok at idle but after warming up chugs and smells like gas.above around 3000 rpm the car clears out the gas smell and runs very strong.
I have replaced plugs, cap, rotor and air and fuel filters.my daughter has replaced the fuel pump twice in three years,the first time it quit running ,the second time she was tring to get it to fix this problem. i've checked the timing belt and it's lined up perfect and is showing no signs of wear. my son inlaw put a set of used injectors in it and it did not change anythig. I bumped the timing up and the car runs alot better at start up but when warm still has the same problem. It is storing no codes on the computer?
now i have a pretty good background in auto repair but would love some input on what else to check. the Manual say's that the distributor has little replaceable parts and controlls injection timing, regular ignition timing and the vtec timing.
If i understand the vtec correctly it seems to be working fine since the car runs good above 3000 rpm? so please if you have any ideas on what to check I would really love some advise! thank you!
Old Sep 18, 2010
Re: 94 civic vtec no check engine light
you on the 7th gen forum, yours is a 6th gen. not that matters that much, but anyway. no, don't know the answer
Old Sep 18, 2010
lazlong's Avatar
EVAP system?
Xuhme
21
Aug 7, 2023 03:40 PM
ashleymmackey
Apr 18, 2015 09:48 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
dooner24
Apr 14, 2015 07:51 PM
bahena08
Apr 11, 2015 05:09 PM
