Front Oxygen sensor for 2004 EX prices
Old Sep 16, 2010
fleathatsme's Avatar
fleathatsme is an unknown quantity at this point
Question Front Oxygen sensor for 2004 EX prices
I'm sorry to fire up a whole new thread for this but I need some insight as to why there is such a huge price difference for the front Oxygen sensor on my 04 EX. I've checked the code (P0135 heater circuit malfunction), I checked the resistance (ohms) at the sensor on the two white wires and found the problem to be in the sensor (Thanks to a previous thread on here that explained this beautifully). Ok so I gotta replace the sensor. No big deal. So I go to my local autozone and they want $250 for a four wire "wideband A/F" sensor. I check at my local Honda dealer and they want $310 (not even a reach around included) I coughed and choked a lil bit and decided to check online. I'm finding everything from "OE"exact fit (color me lazy but I don't want to splice wires) from $60 to $280. If I have to get the high end wideband A/F for it work correctly I'll suck it up and do it but if I can get away with a correct 4 wire unit for less than $100 then I'd like to save a few bucks. This is a bone stock machine and I plan to leave it that way. Somebody enlighten me.
Old Sep 16, 2010
Re: Front Oxygen sensor for 2004 EX prices
did you by any chance look for narrow band sensors? 03+ are wideband.
Old Sep 16, 2010
I've checked multiple sites online and they seem to offer non-A/F 4 wire setups but they do not list them as narrow vs wideband. It is an 04' that comes with the wideband A/F type and I don't want to install anything that won't work correctly. My question is really has anybody used a narrow band in place of the wide band and had it work correctly.
Old Sep 16, 2010
lazlong's Avatar
Narrow band and wide band don't mix.
Old Sep 16, 2010
So to beat this horse completely dead, if it came with a wideband then replace with a wideband and suck it up. Just because a sensor is sold as a 4 wire "OE" compatible this does not make it a wideband alternative. There sure are a lot of online sites/sellers willing to sell you the wrong sensor touting it as an "OE" compatible out there!
Old Sep 16, 2010
it's not about the sensor only, it's about the ECU as well to understand the signal being sent. Likely using the wrong glasses...
Not really sure about the sites you looking at, sorry. I go for the ones that does not offer a 75% off offer, they usually costs 10x more in the long run.
Old Sep 16, 2010
lazlong's Avatar
Yes. #18: http://www.hondaautomotiveparts.com/...PIPE+-+MUFFLER
Old Sep 16, 2010
Thanks for the good advice. I knew you guys could enlighten me.
KillerX
Apr 9, 2017 08:20 AM
hokiedad4
May 3, 2015 10:06 PM
bsmiley
Apr 27, 2015 01:27 PM
chgofirefighter
Apr 18, 2015 08:08 PM
GH04si
Apr 15, 2015 08:13 PM
