Multiple cylinders misfiring!!!
Old Sep 1, 2010
assassin9874's Avatar
assassin9874 is an unknown quantity at this point
Question Multiple cylinders misfiring!!!
First off let me give u some background information... Car is an 02 civic lx. it has a 1.7 nonvtec with is a d17a1.. I boosted it and running aem f/ic.. Its been dynoed and everything was running fine for the first 4 months... then all of a sudden it all started... while driving it feels like its lacking power (hence the misfiring) while going up in the rpms.. and while sitting still idling it has a rough idle and while idling it constantly almost stalls but then catches itself and brings up the rpms... I plug in the code reader and 5 codes come up.. cylinder 1 misfire.... cylinder 2 misfire... cylinder 3 misfire.... cylinder 4 misfire... multiple cylinders are misfiring... idk what to do... any help would be much apprecited!!
Old Sep 1, 2010
Re: Multiple cylinders misfiring!!!
anyone???
Old Sep 1, 2010
spark plugs? youre running copper plugs (ngk or denso) with at least one step colder heat range right?
Old Sep 2, 2010
j00fek's Avatar
j00fek is an unknown quantity at this point
bad coils?
Old Sep 2, 2010
02civicsi02's Avatar
Low and slow!
Check the spark plugs, coil packs, also check timing.
Old Sep 2, 2010
haven't checked the coils yet.. nor would i know how to lol.. I'm running ngk 7's.. they are copper core
Old Sep 2, 2010
if your tune is bad, it can foul plugs quickly. have you taken the plugs out to see what they look like? thats the main cause of misfires. the coil packs can be checked with an ohmmeter. the resistance of all the coils should be close to the same value.
Old Sep 2, 2010
Low and slow!
Yeah this can also be it cause I have heard a couple things bout the aem's that sometimes if the weather changes alot from the tune you got then you will have to retune it.
Old Sep 4, 2010
i'm starting to give up on this car... It went from this problem to now in neutral i rev it up and when it hits 3k rpms it goes into limp mode... I replaced the map sensor and checked for boost/vacuum leaks and didn't find any.. If my tune was messed up, would it cause this problem to occur?
Old Sep 5, 2010
how are your plugs? how do they look like?
Old Sep 5, 2010
plugs show even wear.. no signs of fouling out.. now when u start up the car it runs at 200 rpms and nothing happens when u give it gas... ugh...
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
solarpunk70
Apr 12, 2016 11:43 AM
jtcavey
Sep 30, 2015 02:18 PM
Bruce2
Sep 27, 2015 08:45 PM
Luluharp
Sep 27, 2015 11:56 AM
