Oil Pan Replacement
Old Aug 29, 2010
webster426's Avatar
webster426 is an unknown quantity at this point
Oil Pan Replacement
Hey guys,
I have a 2003 Honda Civic EX and cracked my oil pan. I bought a new one and installed it yesterday.
The new pan fits just fine, but it does not have the holes drilled for the two mounts that attach to the tranny . The picture below show the mounts, the area where they are supposed to go, and the old oil pan holes.
Do I need these mounts? Will it be O.K. if I run my car without these parts?
I know this sounds stupid because they are obviously there for a reason, but why would "Spectra" (oil pan manufacturer) make the same oil pan as OEM just without the holes? All help is greatly appreciated!!!
ID:	79170   Click image for larger version
ID:	79171   Click image for larger version
ID:	79172   Click image for larger version
Old Aug 29, 2010
webster426's Avatar
Re: Oil Pan Replacement
someone.....anyone?
Old Aug 30, 2010
brobo's Avatar
brobo will become famous soon enoughbrobo will become famous soon enough
there are tons of reasons but i dont know you can try sending Gearbox he is an andmin and he knows alot so yea message himk bye
Old Sep 12, 2010
coolwwebb's Avatar
coolwwebb is an unknown quantity at this point
Smile Re: Oil Pan Replacement
Did you have to drop the from exhaust to remove the oil pan? I have a 2001 Civic DX and my oil pan is rusted to hell,,,,
Cheers
Old Oct 30, 2010
JonDorian JD's Avatar
JonDorian JD is an unknown quantity at this point
Cheers
I just replaced my 2002 Civic EX oil pan and I did need to drop the exhaust by the oil pan. I just removed the two flange bolts and then pulled off a support located in about the middle of the car. Just doing this will give you plenty of play to get out the old pan and put the new one in.
The LX/DX/VP is a bit different than the EX with a steel pain, different transmission mounts and the catalytic converter up with the motor instead of underneath - but dropping the first half of the exhaust I would think would be similar.
Old Oct 30, 2010
Originally Posted by webster426
Hey guys,
Did you buy an aluminum or steel pan? The Civic EX with the D17A2 engine (as opposed to the DX/LX with D17A1) uses an aluminum pan with places for those transmission supports. My guess is the spectra pan you bought was for the DX/LX model. Not sure if this will cause any problems not having the transmission braces or whatever they are there
jmdcivic
May 20, 2015 09:52 PM
BootyDo
May 7, 2015 04:46 PM
pheaton
May 4, 2015 08:26 PM
leon1
Apr 28, 2015 07:32 PM
Grey
16
Jan 27, 2002 11:34 PM
