Aftermarket Tach
Old Aug 24, 2010
dustysaw's Avatar
dustysaw is an unknown quantity at this point
Aftermarket Tach
I just bought an aftermarket tach for my car, cuz I don't have one because Honda is so cheap they couldnt put one in the base model. Anyone know how to install it, and if it's an easy job?
Old Aug 24, 2010
Re: Aftermarket Tach
Should be tapping one wire (don't quite know which wire to tap, however) for the RPM input, then finding and tapping a +12VDC wire for any illumination, then grounding the tach to the chassis. Oh, and finding a place to physically mount it, as well.
Old Aug 24, 2010
lazlong's Avatar
You should already have an RPM signal wire in the wire harness. Pull your cluster and check the green connector for the blue wire in pin 20. While you got the cluster pulled might as well do the cluster swap. lol.
Wire colors/pin numbers are on page 4: https://www.civicforums.com/forums/7...faq-video.html
EDIT: Pretty cool place to mount the aftermarket tach: http://cgi.ebay.com/ebaymotors/BLOX-...ts_Accessories
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
UltraHDGames
Jun 8, 2016 05:16 PM
NROD315
Sep 23, 2015 03:46 PM
bhollie
Sep 22, 2015 11:08 PM
MamaBear2015
Sep 15, 2015 09:35 PM
