P250B(168), P2185 (192-2), P2185($0710) Cause and solution
Old Aug 12, 2010
thethinkingman2's Avatar
thethinkingman2 is an unknown quantity at this point
Hi,
I'm new to the forum, I've got a Honda Civic 2.2 cdti 2006. I'm getting the engine management light on and the have had the codes read. They are as following:
P250B (168) Engine oil level sensor range/performance problem
P2185 ($0710) Engine Collant temperature 2 circuit high
P2185 (192-2) ECT Sensor 2 circuit high voltage
I have checked the Coolant sensors and one of the sensors was corroded and damaged. I've replaced both sensors, but still get the bottom 2 codes. I checked the wiring and it seems good, although the bottom sensor housing could look better.
Any suggestions what to do?
Old Aug 12, 2010
grendel's Avatar
grendel has a spectacular aura aboutgrendel has a spectacular aura about
Re: P250B(168), P2185 (192-2), P2185($0710) Cause and solution
double-post
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Bruce2
Sep 27, 2015 08:45 PM
260000milesgoal
Sep 25, 2015 07:41 PM
Bruce2
Sep 21, 2015 08:01 PM
Jrosa
Sep 14, 2015 08:24 PM
