Serious Problems with clutch Pedal!!!! GearBox helpme out
Old Aug 8, 2010
D17cancun's Avatar
D17cancun is an unknown quantity at this point
hello everubody
well i have like 5 months withou my civic 2002 ex coupe
everything started at the mornig of 5 month ago, so in the morning going to work after shift 2nd gear there just comes a big noise like CRACK!!!! then the clutch pedal was on the floor, so i parked the car open the hood and i saw the slave cylinder broken from the screws, so i decied to weld the that part, everything gone ok, so i installed back, pump the pedal to make go out the air from the lines after the 2nd pump the pedal never got back with pressure and now have 1 month on the honda dealer and they can not find the issue.....
good points to:
both cylinder clutch brand new from honda
clutch line is fine
pressure plate is a ACT exxxtreme plate, obviously is why the screws broke
new disc ACT stage 2 and release bearing new (6months)
SO really help me out bro's
if my english is bad sorry about it
I ADDED THIS PIC FROM AND MY CAR TO REINTRODUCE MY SELF IN HERE, BECAUSE I HAD ALONG TIME I DONT POST IN HERE
BEST REGARDS GUYS!!!!!!!!!
Old Aug 8, 2010
D17cancun's Avatar
Re: Serious Problems with clutch Pedal!!!! GearBox helpme out
Nobody???
Riceboy
you can help too
i really,really need some help with this, if somebody has a friend on a honda dealer in usa let him know thhis issue with my clutch
note: I already called to honda mexico and they dont know what to do....
Old Aug 8, 2010
You might have to thoroughly bench bleed the slave and master cylinders before installing them back into the system..
https://www.civicforums.com/forums/1...-pressure.html
Old Aug 8, 2010
D17cancun's Avatar
I ALREADY DID THAT AND ITS REALLY HARD TO ME BECAUSE IS NOT POSITIVE ANSWER MAN
AND THAT WORD THATS WHAT I DID NOT HOW WRITE HAHAHAHAHAHA
"bench bleed the slave and master cylinders" ALREADY DID
Old Aug 8, 2010
D17cancun's Avatar
Txs! Ricebos that link was useful
Old Aug 9, 2010
D17cancun's Avatar
Thanks for helping guys goood site!!!
Old Aug 15, 2010
D17cancun's Avatar
hello there!!
Old Aug 15, 2010
D17cancun's Avatar
hey riceboy
i tried the solution that you told to do
but there is not positive answer from my car what else i can do??????
im really scare about this issue
the Honda dealer are crying together with my car
lol!!!
Old Aug 16, 2010
D17cancun's Avatar
Nobody?
Old Aug 16, 2010
02civicsi02's Avatar
Low and slow!
Hmm this is kinda hard to diagnose especially since we are not there to see. Have you tried maybe the push rod behind the clutch pedal. Have you tried looking at that at all. And you have completely bleed the line where there are no bubbles in the line. Hmm it is kinda wierd that the fluid is coming out and there is still no pressure in the pedal. The only thing I can think of is the push rod.
Old Aug 20, 2010
D17cancun's Avatar
Originally Posted by 02civicsi02
hmm this is kinda hard to diagnose especially since we are not there to see. Have you tried maybe the push rod behind the clutch pedal. Have you tried looking at that at all. And you have completely bleed the line where there are no bubbles in the line. Hmm it is kinda wierd that the fluid is coming out and there is still no pressure in the pedal. The only thing i can think of is the push rod.
it is really strange
here at my honda dealer they want to change all the clutch kit,flywheel, and realese bearing, and pumps they are charging me 1,100 us
im really afraid if that push do not work any other suggestions??
What riceboy told to do did not work
Old Aug 27, 2010
D17cancun's Avatar
After one month on the dealer and almost paying 1,200 bucks
the issue was a 4th time swap by warranty the master cylinder and slave cyl
so if any body have an issue like this you should change the cylnder very very nice
best regards
Old Jul 21, 2011
Rockstar18729's Avatar
Rockstar18729 is an unknown quantity at this point
I am having the hardest time finding the slave cylinder in my 02 Vic. I have looked at pictures til I'm blue in the face but can't find the thing.
I know where about it's suppose to be but I don't see anything that looks like it. Can somebody help me? Picture? Video? Magical midget? SOMETHING!!
I am fairly new to working on cars so sorry if this question sounds off the wall.
Thanks
Old Jul 21, 2011
pheaton's Avatar
A descendant of 2k1civic.com
On my '01 it's located on the passenger side between battery and engine, behind a rubber booty thing.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
ghondavic
Transmission
Apr 12, 2017 09:37 PM
bsmiley
Apr 27, 2015 01:27 PM
delacampos
Transmission
Jan 2, 2002 02:06 PM
02EXCoupeGuy
Dec 19, 2001 09:47 PM
