Odometer after battery replacement
Old Aug 5, 2010
coachdiver's Avatar
coachdiver is an unknown quantity at this point
Has anybody had this happen ? Whats the fix ? Parts store replaced my battery and when started car no odometer ? I reset the radio with radio code but no odometer is there a code for the odometer never had to do this before car 2002 crv
Old Aug 5, 2010
xtreme698866's Avatar
xtreme698866 is an unknown quantity at this point
Re: Odometer after battery replacement
the same hapend to me i think...still waiting for response...but first thing to do is to reset your ecu by disconnecting your negative battery terminal as long as you can but unluckily this one did not work on me maybe it will work on you just try it
https://www.civicforums.com/forums/1...triggered.html
Old Aug 6, 2010
i figured out mine...disconnect your negative terminal first and leave it for 15 minutes then insert you key at the ignition before connecting your negative battery terminal.
Old Aug 6, 2010
coachdiver's Avatar
Thank You That WORKED Again Thanks
CarStuff
Dec 6, 2020 12:52 PM
Dorval Andre
Electrical
May 6, 2015 02:33 PM
tylerginevan
Apr 27, 2015 12:29 PM
smmahan
Apr 15, 2015 08:17 PM
thesushiboy
Apr 12, 2015 02:54 AM
