kpro windows 7 64 bit error
Old Jul 9, 2010
army12bc's Avatar
army12bc will become famous soon enough
So i'm starting kmanager and it doesnt do anything. i checked my event logs and i get this.
Faulting application name: KManager.exe, version: 1.4.0.0, time stamp: 0x00000000
Faulting module name: KManager.exe, version: 1.4.0.0, time stamp: 0x00000000
Exception code: 0xc000001d
Fault offset: 0x003312ea
Faulting process id: 0x13f8
Faulting application start time: 0x01cb1f99df66a447
Faulting application path: C:\Program Files (x86)\KManager\KManager.exe
Faulting module path: C:\Program Files (x86)\KManager\KManager.exe
Report Id: 1e4e5b7d-8b8d-11df-ac5d-00269e9668da
this is second error in event log
Windows cannot access the file for one of the following reasons: there is a problem with the network connection, the disk that the file is stored on, or the storage drivers installed on this computer; or the disk is missing. Windows closed the program K-Series ECU Manager because of this error.
Program: K-Series ECU Manager
File:
The error value is listed in the Additional Data section.
User Action
1. Open the file again. This situation might be a temporary problem that corrects itself when the program runs again.
2. If the file still cannot be accessed and
- It is on the network, your network administrator should verify that there is not a problem with the network and that the server can be contacted.
- It is on a removable disk, for example, a floppy disk or CD-ROM, verify that the disk is fully inserted into the computer.
3. Check and repair the file system by running CHKDSK. To run CHKDSK, click Start, click Run, type CMD, and then click OK. At the command prompt, type CHKDSK /F, and then press ENTER.
4. If the problem persists, restore the file from a backup copy.
5. Determine whether other files on the same disk can be opened. If not, the disk might be damaged. If it is a hard disk, contact your administrator or computer hardware vendor for further assistance.
Additional Data
Error value: 00000000
Disk type: 0
third error for same event
Fault bucket 1733587166, type 1
Event Name: APPCRASH
Response: Not available
Cab Id: 0
Problem signature:
P1: KManager.exe
P2: 1.4.0.0
P3: 00000000
P4: KManager.exe
P5: 1.4.0.0
P6: 00000000
P7: c000001d
P8: 003312ea
P9:
P10:
C:\Users\George\AppData\Local\Temp\WERF540.tmp.WER InternalMetadata.xml
These files may be available here:
C:\Users\George\AppData\Local\Microsoft\Windows\WE R\ReportArchive\AppCrash_KManager.exe_5486309e9544 9fac5f1d2d61e1cdaf6a4394e6_1bdc0a37
Analysis symbol:
Rechecking for solution: 0
Report Status: 0
mjdiaz89
Jun 21, 2016 09:26 PM
jessica19699
Jul 29, 2015 05:51 AM
breanna_17
Jul 21, 2015 04:01 PM
1khilari
Jul 9, 2015 08:12 PM
ballmich
Jul 9, 2015 11:59 AM
