new axels,transfer axle, bearings, tie rod...plz help
Old May 17, 2010
220918miles's Avatar
220918miles is an unknown quantity at this point
Exclamation new axels,transfer axle, bearings, tie rod...plz help
220,918 miles. repeating thud,thud,thud noise getting worse. first new tires, alignment. no difference. new passenger side tie rod end, both ball joints. no difference. new axles (including transfer axle bearing). no difference. Now should i replace both front wheel bearings? Yes it makes more noise when turning(especially to the right) than when going straight. yes the sound increases with wheel RPM. Does not appear that sound is in the transmission. noise coming from front wheels. i can not get any information on a fix. has anyone come across this?
Old May 29, 2010
vanser3004's Avatar
vanser3004 is an unknown quantity at this point
Re: new axels,transfer axle, bearings, tie rod...plz help
Maybe try to replace shock absorbers.
Old Jun 7, 2010
shwoogie420's Avatar
shwoogie420 is an unknown quantity at this point
sound like your wheel bearings are shot....maybe all four if that is how many miles you have on it and they are the orginal stock ones
Old Jun 7, 2010
BlueEM2's Avatar
Whachya lookin at?
Have you replaced the compliance bushings yet? They fail often and quickly on these cars.
Sep 26, 2023 06:44 PM
Scout1
Oct 5, 2015 01:33 PM
rainman15
Sep 6, 2015 11:10 AM
17
Jul 23, 2015 11:48 PM
