Rear End Noise
Old Mar 9, 2010
BlueEM2's Avatar
Whachya lookin at?
Rear End Noise
I haven't had a chance to check it out yet but I will describe the issue, which is hard to do. I have a noise coming from both rear wheels that sounds like a rubbing noise. It happens mostly over bumps (when the suspension is doing up/down motions), or when releasing the brake and getting off to a start. Happens at all speeds. I'm wondering if there is anything common that could be wrong back there. Why would it be both wheels??? 140, 000km on 2005 Civic EX.
Old Mar 11, 2010
ExistEvolution's Avatar
ExistEvolution is on a distinguished road
Re: Rear End Noise
is it a creaking/squeaking sound? Check your bushings
Old Mar 11, 2010
BlueEM2's Avatar
Whachya lookin at?
Re: Rear End Noise
Yea it is. I've done some research on here and I'm just going to spray them with white lithium grease and see if it improves it. Thanks.
Old Mar 16, 2010
Protan988's Avatar
Protan988 is an unknown quantity at this point
Re: Rear End Noise
Probably both stabilizer links. Mine are doing the same and need to be changed. Simple cheap and easy repair.
Old Mar 17, 2010
Re: Rear End Noise
you can get replacement links for cheap, i just have other concerns and have no replaced them
Old Mar 17, 2010
BlueEM2's Avatar
Whachya lookin at?
Re: Rear End Noise
Hmm, yes I lubed everything up with lithium grease back there and there is still lots of noise. I'll try the stabilizer links next because I can't stand listening to it any longer.
Thanks everyone, I'll post if it corrects the issue.
stryder12
Jun 30, 2015 08:33 PM
helpnoobplease
Jun 9, 2015 10:18 PM
EliteImports
Mid West
Dec 17, 2001 03:22 PM
aZnVoYCe
Dec 1, 2001 09:33 PM
CivicHX01
Nov 29, 2001 03:48 PM
