Emission Control Light on - Engine Revs on its own
Old Mar 8, 2010
cbags05's Avatar
cbags05 is an unknown quantity at this point
The past week or so I noticed my engine reving a little bit on its own when in idle...I figured maybe the the throttle cable was sticking because if I punched the gas a little it would settle down. But have not had time to play with it yet.
Then today it got a lot worse and the emissions control light came on. So now it seems more complicated than I had anticipated. I did read a few threads of fairly similar nature saying that resetting the ECU could work?(unplug the battery for a few minutes) I thought about getting an OBDII reader to see what kinds of codes are coming through, but any advice would be helpful. This is my first problem with the 2002 EX 5 sp.
Old Mar 9, 2010
cbags05's Avatar
Re: Emission Control Light on - Engine Revs on its own
If anybody can help...
Reset the ECM, light went away. Idling right now, and revs in repeating cycles...up to about 2000 RPM and back down to normal idle speed then back up again every 5-10 seconds. Sound like a throttle body/vacuum system issue?
Old Mar 9, 2010
check the engine code. its prolly a tps sensor problem on the throttle body.
cloudguy
Apr 28, 2015 05:02 AM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
smmahan
Apr 15, 2015 08:17 PM
bahena08
Apr 11, 2015 05:09 PM
locozoko
Nov 8, 2001 06:33 PM
